Backup Light Switch
stevoidnic
Backup Light Switch
Post by stevoidnic »
Where is the backup light switch located?
In the transaxle nose cone next to where the shifter shaft enters the transaxle on the front of the transaxle.
stevoidnic
thanks
The 1966 Beetle did not have backup lights. They were first introduced in 1967.
Good catch. But, he did not say he was asking about a 66. Or, could have been added. Either way, good catch.
This is 1966VWBeetle.com, so we can assume. :wink:
So you know, before they became standard in 1967, the accessory application for backup lights was usually only one light on the left side. They were a dealer installed item like radios, antenna and AC units. So, he may have one on a 1966.
Sorry I had to crop this 1961 ad and shrink to fit.
Oh I forgot to mention, if it were a dealer installed item, they would have used a mechanical switch manufactured by Hella that mounted inline on the speedometer between the speedometer and the cable. If it is still there it can be found under the under the hood on the back of the speedo When the nechanism senses the cable rotating backwards in reverse, it closes the switch, activating the reverse lights. It has two wires with one attached to the fuse box and the other extended to the rear of the vehicle to attach to the reverse light.
Again sorry I had to crop the picture.
There was also an accessory switch that attached to the shift coupler inside the tunnel under the back seat.
But once again, these were accessories, not standard equipment.
If you have your heart set on backup lights, the nosecone from a '67 to '71 transmission is interchangable.
