Which rust repair panels to use??
Having a hard time getting a straight answer out of Cip1, so thought I'd ask on the forum here: These 2 rust repair panels 'seem' to be for the same area just in front of the rear wheels, but I can't tell for sure. Does the VNG panel cover the same specific area as the small TAB panel ..only give more coverage in the area, or do they go in completely different areas??
- panel 2.JPG (28.66 KiB) Viewed 6066 times
- splash panel 1.JPG (27.03 KiB) Viewed 6066 times
Okay...thanks. That's helpful. I think I'll go with the ones that have more coverage ...pretty sure I'll need it.
- driver side rear wheel area.jpg (99.26 KiB) Viewed 6011 times
In case you need a bigger piece, this is where I found mine:
http://www.mtmfg.com/vw/2118/Volkswagen ... Wheelhouse
They have the whole wheel well.
