Engine tin and heat riser covers line up
I'm struggling with lining up the engine tin with the heat riser covers...could someone send me a picture of how they sit when installed? Is the heat riser cover supposed to rest on top or under the engine tin? I currently have the cover sitting on top and it doesn't seem quite right...
I figured it out...the engine seal was not correctly positioned and it was preventing me from lining all the tin parts in the proper spots...
1300
Post by 1300 »
Do you put the rubber gasket on top or bottom of breastplate? I always put it on top, but had trouble getting fresh air hoses one. Then switched to bottom. Not sure how it was from factory. Casey
I think the factory seal hugs the breastplate partially hovering over (on top)...my rubber seal is broken in several spots and not properly set. I need to install a new one. I have the new engine seal from Wolfsburg West and I have been dragging my feet because it's not an easy install in such tight quarters...one of these days I'll tackle it...
