I pulled my distributor to give it a good cleaning and noticed that the fiber washer was not located inside the housing, rather it was external with two steel washers. The third steel washer was inside where the fiber washer was supposed to be (at least from the exploded diagrams I've been using!). So the fiber washer looked a bit rough - it was in one piece, but when I turned it into the light I could see that small surface areas had worn off. So I want to replace the washer and locate it properly.
But where do I find one?
I looked at some places online and didn't see the exact washer listed.
