dual carb adjustment
Author Message
jeff930
PostPosted: Sun Sep 27, 2009 6:18 pm    Post subject: dual carb adjustment Reply with quote
i have dual webbers on my 1914 motor and they were recently tuned for down the hill but now its about 7000 feet in altitude... what adjustments do i do other then the idle Question Question
Back to top
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Tue Sep 29, 2009 12:20 pm    Post subject: Reply with quote
As you go higher, you run richer because the air thins out, so the odds are you're going to either need to tweak your A/F ratio or rejet. Depends on your setup right now and what your tuning elevation is set for currently.
Give this a shot.
http://www.thesamba.com/vw/forum/viewtopic.php?t=328611&highlight=altitude
How are you jetted right now? How is your engine set up? Give us a rundown, as the parts inside will also make a difference in how your jetting should be set.
There's a lot more to it than just changing the idles. The adjustments required will be different for every setup. There's a lot of plug reading and jet tuning inolved and if you're not accustomed to doing it, you'll probably have to make several jet adjustments to get it right.
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
