poor starting/running--need diagnostic help
exprof
Post by exprof »
My '66 has a 1600 dual port with a Solex 30/31 PICT carb. When it is cold, the engine dies within a couple of seconds of starting. It also sputters and hesitates when I step on the accelerator unless I press it very firmly. If I simply touch the pedal with my foot, the engine quits. I have to rev the engine higher than one normally would in order to start out in first gear. Also, the exhaust smells as if the mixture is overrich.
Thanks in advance for any and all help.
It sounds like it is flooding out when you touch the gas pedal. My guess is that you are correct in thinking the mixture is too rich.
exprof
Post by exprof »
I'll adjust the mixture and we'll see if that does the trick.
couion
Post by couion »
Double check the choke to see if it is adjusted too tight. This would cause it to get too much fuel and not enogh air.
exprof
Post by exprof »
I leaned the mixture and it seems to be running o.k.; at least it's not gagging when I step on the accelerator. I'll check the choke also.
Thanks for all your help.
