front beam
front beam
Matt: thanks for the list. we'll see how it goes!!!
front beam
Matt: what size hex wrench removes the grub screw from the torsion arm?? Got most of the old beam apart. hard time getting the tie rod ends out. what a job!!!
- Moderator
Re: front beam
Billbill hauck wrote:Matt: what size hex wrench removes the grub screw from the torsion arm?? Got most of the old beam apart. hard time getting the tie rod ends out. what a job!!!
8 mm is the ticket....tie rods are always a pita
dont worry about it once you put heat on the rod it will turn...
replace with good german ends,,,,if you need anythingelse you know how to get in touch....
matt
front beam
thanks Matt. might have to contact my mechanic buddy. he has a torch.
I don't think a hand held propane torch will do it.
front beam
Matt: any trick to getting the torsion bars back in?? do they go in one at a time or am I missing something?? they seem to catch in the center near the indentations.
By the way, the ball joint press did not work. Will have to take it to a pro.
- Moderator
bill
GO TO MY SITE AND LOOK AT THE BEAM REBUILD LOOK AT ALL THE PICTURES C CLAMP http://volksbugusa.shutterfly.com/
the grub bolts should not be set in untill the one set of arms are installed on one side and then install the grub bolts on that side...you should be able to see the half moon on the spring plates to line things up as you are sliding the arm on.Some time the spring plates will move and you will see this by keeping an eye on the other side. No big deal just use a rubber mallet and hit the spring plate and keep looking for the half moon to take shape on the side that you are trying to install the first set.I always use one super big c clamp and kind of wedge it on one of the beam corners and then the screw down side of the clamp on the edge of the torsion arm.This will compress against the new beam seal.....if you still have problems email me at
volksbugusa@optonline.net i will give you my cell # we will talk
cheers[/b]
cheers[/b]
front beam
I see the photos: Do you intall the torsion bar ends in the torsion bar end first, screw down the grub screw and then insert the bars in the beam??? I do see how all the indentations line up.
I assume, then, that I could use a rubber mallet to tap in the bars hitting the outside end ot the torsion arm, correct??
- Moderator
front beam
Matt: can't seem to get the torsion bars in. What am I missing?? Even separating them I cannot get them all in.
- Moderator
bill lets start from the beginning
-remove all the grub screws
-clean torsion bars
-coat bars with clean multi purpose grease
-aline so the the countersunk recesses are perfect
-slide the set of bars into the beam
-aline the center of the bar with the hole for the set screw
thats it
i think you forgot to remove some grubs let me know
matt
-clean torsion bars
thats it
matt
front beam
can't seem to get the torsion springs installed. even in sections, cannot get all of them in.
should I "tape" the end I am inserting to try and keep the leaves together?
- Moderator
Re: front beam
BILL YOU CAN ONLY USE GREASEbill hauck wrote:can't seem to get the torsion springs installed. even in sections, cannot get all of them in.
-clean torsion bars
thats it
matt
_________________
- Moderator
bill
if you are still having a problem try this after cleaning and re applying grease to all the plates.line up the half moon holes,then take a c clamp and clamp the plates together on the one end and spot weld the plate edges...dont go crazy just a little zap to hold..once thru
you can grind the weld spots off GO EASY PLEASE....
let me know
let me know
front beam
to all interested in this item, Matt's suggestion about a bead of weld on the tip of the torsion bar cluster did the trick!!! Many thanks to Matt for the suggestion.
Back in the day of the rusty Beetle, they used to sell weld-in repair kits for the front axle beams. Ball joint Beetles typically rusted out on the shock towers between the two front alxle tubes, and this kit fixed the problem without having to tear out the front end. I still have one of these kits buried away somewhere...
Finding one and installing it might be your best bet.
