Throw-out bearing??
Dtown66bug
Throw-out bearing??
Post by Dtown66bug »
My car will not go into gear with the car is running. I push the clutch in and she will just grind in any gear. With engine off, it freely goes into gear. I had heard that it could be a throw-out bearing. I am not sure about. Is there any maintenance check I can make or do that might fix problem or is this a "pro" job.
Thanks for the help.
John
How's your clutch pedal free play? Do you have room for adjustment?
What about the bowden tube? How much sag's it got?
