Bosch distributor rebuild/replace
exprof
Post by exprof »
Are rebuild kits available for Bosch vacuum advance distributors? I have two that I'd like to rebuild because they both seem to have some slop in the driveshafts and I don't want to go to a 009 distributor. The one that's presently in the car has slipped timing a couple of times and seems to be causing a misfire. If rebuild kits aren't available, can I find rebuilt distributors or comparable replacements?
Best person around MASTER OF MASTERS when it comes to rebuilding and shimming a Dizzy
Glenn even has a sun testing machine
http://www.glenn-ring.com/010/
All you need to know about Glenn in on the Samba site...
X2
exprof
Post by exprof »
Thanks; I'll check him out.
