I am thinking about putting J tubes on my beetle. Don't drive it in the winter and don't really need the heat.
Q: how doe the lack of heater boxes affect the cooling of the motor?? Do the fresh air hoses still go to the muffler or does one just block them off?
How do the lower cooling tins attach to anything other then the crankcase??
J-tubes
I live in Phoenix. I run a header and J tubes. I don't notice any difference on the temp gauge vs heater boxes. By that, i mean I don't overheat by running the J tubes, My gauge isn't accurate enough to tell me if I'm 5 degrees hotter or cooler, just not that granular. Cap off the ducts. most places sell the caps or you can get good ol' freeze plugs. I like the look of the accordion hoses vs the ugly capped off shroud, so I put the hoses back on for looks only. I have the lower tins sitting on my work table while I try and come up with a better solution than bailing wire to the J tubes. Thought I saw some tins designed for J tubes somewhere but now I can't find what I was looking at.
j-tubes
Thanks for the replies. I think I will give them a try.
I like the look of the fresh air hoses also so I will cap off the outlet ports and put the hoses back on.
bill hauck,
What ever you do...If you do eliminate the heater boxes and install the "J" tubes, you must block off the ports on the fan shroud for that would be the path of least resistance in the air flow and not cool the cylinders!! For then, it will over heat! Cause the cylinders to elongate and then the rings can no longer seal. Not to mention, when it cools back down, you might have to retorque the heads.
Brian
Brian
J tubes.
I agree. I know someone who "cooked" his motor by not having the fresh air tubes on ddn't have the ports blocked off. I have ordered some from CIP1
- Moderator
j-tubes
Matt: yes, I do have a 1660 with a dog house cooler. also will put the J-tubes on a '59 single cab with a 1600. Neither car will be driven in a Minnesota Winter!!!
Baby food caps??
I've just gotten back into all this after being around it all as a kid. I remember my father used to use baby food caps to block off the ports in the summer time. They would fit right on, nice and snug. I guess you might be able to put the tubing back on over them for looks if you wanted.
Dustin
Dustin
