wiper switch
exprof
wiper switch
Post by exprof »
I had to replace my wiper switch, but the only one that I could get was a for a '67. Unlike the '66, the '67 has two speed wipers.
The switch didn't come with a wiring diagram. After trying to wire the switch myself, I took the car to my mechanic. He got the switch to work, but it activates the wipers at the second switch position, and when I turn the wipers off, they don't "park" as they should but stop at the uppermost point of their travel unless I activate the switch when the wipers are on their way down.
How do I wire the two speed wiper switch to park the wipers when I turn the them off? If there is no way to do that, is there somewhere that I can get a switch for single speed wipers?
Here's a place you can get the single speed switch:
http://wolfsburgwest.com/cart/DetailsLi ... 113955517C
exprof
Post by exprof »
Thanks!
Here's another - I noticed wolfsburg is temporarily out of stock
http://www.bfyobsoleteparts.com/1958-67 ... r-737.html
empiracer1966
Post by empiracer1966 »
exprof...
You should be able to use the '67 switch...before I had a 2sp 12v '67 wiper motor, I too and did indeed use a '67 switch...the way I did it was converged the two years schematically and lighted out the '67 switch to figure out what terminal did what...and this is what I came up with...
If you can read the terminal numbers one the '67 switch the wiring would be as follows...
terminal 30--receives POWER from the fuse block
terminal 53b--gets NO connection (it would go to the HIGH speed of the '67 wiper motor)
terminal 53--use the original BLACK w/PURPLE stripe, it would then go to terminal 54d, ("d" as in dog) on the original wiper motor
terminal 53a--use the original solid BLACK wire from the "original" switch terminal 54 and this wire goes to terminal 54 on the original wiper motor
terminal 31b--("b" as in boy, look close as they are small :shock: ) use the original BROWN wire and connect it to the 31b terminal on the original wiper motor
terminal 31--this terminal I made up a New wire and connected it to chassis ground as this it the way it would be on the '67.
I hope this works for you, and "passes the SMOKE TEST" :cry: if it still dosent want to "park" then possibly prior fingers might have broken the pin and or micro like switch in the wiper motor which rides on a cam inside. I did run into that sometime back, early in my "Dubbin" years :D
Brian
exprof
Post by exprof »
Thanks, Brian!
I'll give this a try.
I have one question, though:
Where did you ground the wire going from terminal 31 to ground?
empiracer1966
exprof...
I ran a wire (from an old harness to match the rest of the patina) from the terminal to the support bar at the wiper motor mount...hidden :o
Brian
exprof
Post by exprof »
Good idea; I think I'll do the same. Thanks again.
exprof
Post by exprof »
Brian,
I rewired my switch this morning using your instructions. It works like a charm.
I found, though, that the guy that I had install the switch apparently removed the brown wire from the motor terminal 31b, so it was necessary to fabricate two wires: that one and the one from terminal 31 to ground.
If we didn't live so far apart, I'd buy you a beer. :wink:
Thanks again,
Exprof
