gas gauge adjustment
Is there some way to adjust the float for the gas gauge?? ran out last night and the gauge showed a quarter of a tank.
If memory serves me right, there is a screw behind the gauge that adjusts the reading. So with your tank empty, turn the screw so that your gauge reads empty - Note: Don't be surprised if the guage doesn't read completely full after you do this but the good news is that you will know when you are going to run out. Good luck.
fuel gauge adj.
Thanks!! I'll have to check this out next time the tank is empty.
- elkluvadore
I put a gallon of gas in my tank and put the needle at empty. That way I
know when I'm getting down to the Empty mark I need to start looking hard. I rarely let mine go that far down anyway as the float tends to move up and down quite a bit in the tank when the car starts and stops.
Fuel float adjustment
I just filled it up with gas and thinking the float adjuster was the way to get the fuel gauge light bulb out, turned & turned it (counter-clockwise). When I realized what I was doing I turned it back - but it still says empty.
So my 2 questions:
1:How do I get the fuel gauge to read accurately again?
2:Where's the light bulb?Tell me it's not behind that impossible-to-turn dial just above the float screw on the back of the gauge.
So my 2 questions:
Found fuel light,still inaccurate fuel gauge
I got the bulb out that lights up the fuel gauge. Still having an 'empty' reading on a full tank though..
