What kind of oil do you recommend using in a standard 1300cc
restocal63
Post by restocal63 »
Hi to all,
What kind of oil do you recommend using in a standard 1300cc engine?
Overhere its kind of getting hard to find standard multigrades, as these oils are being replaced by semi-synthetics and fully synthetics.
The engine in question is from a 66 bug (F code) still has approx 57,000 original miles.
Should I use multigrade 15w/40 or 20W/50?
Here in Malta the temperature can vary from 55ºF to 95ºF.
Can you also recommend to me the most suitable brand type.
Normally I run Silkolene Silkolube 20W/50, with API SF/CC ratings.
Is this oil correct? Does it give enough lubrication for all the year round temp?
Thanks for yur help!
exprof
Re: What kind of oil do you recommend using in a standard 13
Post by exprof »
restocal63 wrote:Hi to all,
While 20W50 works reasonably well, it can be a little thick at low temperatures, leading to hard starting. This might not be much of an issue for you, since as you state, the temperature on Malta doesn't get much below 55ºF. (Sounds like a pleasant climate; I might like to visit there sometime :) ).
If the only choices you have are either 15W40 or 20W50, I would opt for the heavier grade in hot weather, and the lighter in lower temperatures. That, though, is only my opinion.
Straight 40 wt if you can get it. Otherwise run the 20w50. You're not going to hurt that motor if your lows are in the 50s running the heavier oils. I live in the desert, and run 20w50 year round (temps range from 30's F to 120's F). Never had a heating problem and I'm an "idle or full throttle" kind of driver.. All my friends who drive baja/race buggies run straight 40wt.
the true fact about oil
Oil
What motor oil is best for my aircooled Porsche?
(or any high performance engine)
by Charles Navarro
Last Updated 02/12/08
The purpose of proper lubrication is to provide a physical barrier (oil film) that separates moving parts reducing wear and friction, but there are many surfaces within an engine that operate with metal-to-metal contact, again popular belief, that are very highly dependant on a strong and robust anti-wear film. The top piston ring operating in sliding contact with the bore operates in a mixed lubrication regime consisting of both boundary (metal-to-metal direct contact) as well as hydrodynamic (oil film between moving surfaces) lubrication. The majority of non-corrosive wear occurs where boundary lubrication exists, especially at cam lobes, tappets, cam follower/buckets, and rockers. Oils contain dispersants, friction modifiers, viscosity modifiers, anti-foam, anti-corrosion, antioxidant and anti-wear additives, all of which can affect the strength and durability of anti-wear films. The focus of this study is on the levels of zinc and phosphorus found in motor oils and their interactions with other additives, more exactly, the zinc (Zn) and phosphorus (P) that makes up the anti-wear additive ZDDP, zinc dialkyl dithiosphosphate, as the ZDDP level is causing concern for all older engines, including aircooled Porsches, with modern oils.
What general characteristics make motor oils specifically well suited to an aircooled or other high performance engine? Aside from recommendations issued by Porsche, what makes a good oil? These oils must be thermally stable, having a very high flashpoint, low noack volatility, and must “maintain proper lubrication and protect vital engine components under the extreme pressure and the high temperature conditions” found in aircooled Porsches. Porsche recommends and uses Mobil 1 0w40 as a factory fill in new vehicles and their 15w50 has been a popular choice used by many in the aftermarket in aircooled models. What was once considered a 'safe' oil is no longer as many of these lubricants have been reformulated for many reasons, not limited to allow for protection of emissions controls and for longer drain intervals.
Porsche’s recommendation in hand, our initial analysis from 2005 and 2006 and from virgin oil analyses going back to the 1990s, we found that then recent SH/SJ/SL formulations of Mobil lubricants tested, including Mobil 1, have had similar 0.12-0.14%or higher Zn and P content. Newer SM formulations of Mobil 1 have less Zn and P, most limited to 0.10% or less to meet ACEA or API requirements. This confirms the industry wide trend of the reduction of Zn and P from motor oils, with the eventual reduction to 0.06-0.08% or even worse, the elimination of these additives, which are essential to an aircooled Porsche engine's longevity.
Many Porsche repair shops have acknowledged that these newest SM and CJ-4 motor oils are not sufficient for protecting any Porsche engine. With longevity and the protection of vital engine components in mind, many shops are recommending non-approved motorcycle or racing oils, or the addition of oil supplements at every oil change, for their higher levels of protection.
Oil companies have been cutting back on the use of Zn and P as anti-wear additives and switching to alternative zinc-free (ZF) additives and ash-less dispersants in their new low SAPS oils since Zn, P, and sulfated ash have been found to be bad for catalytic converters. One such ZF dispersant/anti-wear additive is boron, which does not foul the catalysts in the particulate emissions filters or catalytic converters. For most owners, the reduction in longevity of a catalytic converter is a small price to pay considering the many thousands of dollars it costs to properly rebuild a Porsche engine. It is worth noting that most Porsches have lived the majority of their lives with high Zn and P oils as found in API SG-SJ oils as late as 2004, and we never hear of problems with their catalytic converters.
In addition to protecting emissions controls, there are many other design considerations in formulating engine lubricants, which include improving fuel economy and longer drain intervals. High friction can result in areas with boundary lubrication or where high viscous friction forces and drag may occur with hydrodynamic lubrication in bearings. The use of friction modifiers, such as moly (there are many different species of Mo-based friction modifiers, help to reduce friction in metal-to-metal contact with the formation of tribofilms characterized with their glassy, slippery surfaces. Lower viscosity motor oils are key to increasing fuel economy by their reduction in drag where high viscous friction occurs in hydrodynamic lubrication. While lower viscosities improve fuel economy greatly, they also reduce the hydrodynamic film strength and high temperature high shear viscosity of the motor oil, factors both of which are key to protecting high performance engines, especially aircooled ones.
However, it is worth noting that these new API guidelines do not need apply to “racing,” “severe duty,” or any motor oils that do not carry an API “starburst” seal or clearly state for off-road-use only. Motor oils meeting “Energy Conserving I or II” standards should be avoided as well as those with an API SM or ILSAC GF-4 classifications. The European ACEA A3/B3 classifications, which place a cap on P levels at 0.10-0.12% but allow for higher Zn levels, to be better in taking into consideration wear and engine longevity, setting much lower wear limits, while still limiting emissions and protecting emissions control devices. It is common to find API SJ rated oils, particularly those meeting Volkswagen's stringent 505.01 standard for PD TDI engines, to also meet ACEA A3/B3 requirements. The current ACEA A3/B3 classifications require higher high-temperature high-shear (HTHS) viscosities, stay in grade sheer stability, and tighter limits on evaporative loss (noack volatility), high temperature oxidation, and piston varnish. This makes oils meeting these ACEA standards that much better for your Porsche, especially since wear limits are much more stringent for valve train wear, 1/6th to 1/4th the wear allowed in the sequences for API's newest SM or CJ-4 standards. Of particular interest is the upcoming ACEA E9 standard to supersede the API CJ-4 standard in Europe, creating a classification for low ash oils that are low detergent and are very effective in controlling wear in legacy engines.
Failure to use the right oil, use proper filtration, or observe proper changing intervals can affect the performance of even the best motor oil. This also includes changing the oil too often (needlessly bad for the environment and your wallet) or not often enough. Against conventional wisdom, engine wear decreases as oil ages to a certain extent, which means that changing your oil more frequently actually causes engine wear; these findings were substantiated by studies conducted by the auto manufacturers and petroleum companies, leading to drain intervals increased from 3,000mi/3 months to 5,000-7,500mi/6 months in most domestic vehicles, using mostly non-synthetic oils. Based off of extremely long drain intervals recommended by most European manufacturers, some in excess of two years and 20,000 mi, some users have found it best to reduce those intervals by half or even a quarter. Porsche for the 2008MY has reduced their extended drain intervals significantly to one year/12,000 mi, which is actually less miles than Porsche recommended back in the 1990s with 964 and 993 based aircooled 911s.
Vehicles with track time or sustained high oil temperatures or RPMs should have their oil changed after every event. Vehicles subjected to very short drives or sustained operation in heavy traffic should indeed be serviced more often. Likewise, vehicles not driven often but driven hard a few times a year can probably go a year between oil changes, but that doesn't mean you shouldn't use a good oil! Regular used oil analysis is the best way to determine ideal drain intervals for your driving habits - one good rule of thumb I have seen quoted is to change the oil with the TBN, or total base number, is reduced by 50% of the original total (requiring you to also know your oil's virgin TBN). Other factors to consider are fuel dilution and shearing out of grade when determining your drain interval. With this knowledge in hand, using a quality motor oil with proper filtration and regular service is the best thing to do for your engine and to protect your investment.
restocal63
Thanks for your answers, really interesting!
