Here's one for y'all-
When I turn my ignition to the 1st stop, my idiot lights come on. after I start the car, and the RPM's get up, both the red and green lights go out. The red light stays out, until I turn on my headlights, then it comes on very dim. As I rev the engine, the red light gets slightly brighter, and then at idle it goes out. Everytime I up the RPM's, the light will come on dimly, and glow brighter as the RPM's go up.
I've checked for shorts, but I can't find any. It only happens when I have the lights on. During the day it stays off.
I am still running a 6v system. I will be switching over to 12v in a week or two, but am curious about this problem.
Any ideas?
Strange electrical problem
Still sounds like a short to me. Perhaps something is touching under where all the connections are made - Also check under the hood where the wires connect to the alternator. Also make sure the brushes are good. Perhaps the added electrical load of the lights is just enough drain to key the light on. There just isn't a lot of juice in the 6 volt systems to go around. Good luck.
