Wrist pin part number 1300
Does anyone know the part number for the 1300 wrist pin? My part book lists the same number 113 107 411 for 40hp and 1300. I have a set of German pistons and cylinders with rusty pins and looking for new ones. Casey
Not sure if this will help, but I have bought parts from these guys before and they are pretty good.
https://www.autohausaz.com/pn/13682683- ... gJt2fD_BwE
Thanks. 1300 and 1600 use different wrist pins. The 1600 are longer due to bigger piston diameter. 85.5 for 1600 and 77mm for 1300. I bought a set of 1600 wrist pins a few years ago and had a machine shop cut them to correct length for 1300. Labor rate was more than the price of the wrist pins! I may have go that route again if no luck. Casey
Might try calling Bughaus to see if they have them in 77mm length.
https://www.bughaus.com/Connecting_Rod_ ... 05431A.htm
If not, I would think that if you are careful you could shorten them yourself.
