Heat Riser tins
Heat Riser tins
So I bought aftermarket rear engine tin and just now noticed that they are missing part of the heat riser tin, the part attached to the breast plate is not there. Other than buying an older one (which I know now I should have) any way to get the heat riser area covered?
is this what you need?? http://www2.cip1.com/ProductDetails.asp ... C-C10-6410
