Help! How to remove door/handle tight screws
Author Message
PostPosted: Sun Aug 06, 2017 12:19 pm    Post subject: Help! How to remove door/handle tight screws Reply with quote
I need some tips/advice on how to remove the tight door and handle screws.
I'm working on my restore projects and this seems to be my biggest issues so far.
Thanks
(Please ignore the same post done in the "restoration projects" section).
Back to top
PostPosted: Sun Aug 06, 2017 11:37 pm    Post subject: Reply with quote
Impact screw driver... just seen it in a VW manual...wow!! Any other options for lack of access to such a tool??
Back to top
PostPosted: Mon Aug 07, 2017 9:29 am    Post subject: Reply with quote
Vice grips on a screw driver and turn as you strike the screwdriver with a hammer.
Back to top
1300
PostPosted: Mon Aug 07, 2017 10:08 am    Post subject: Reply with quote
The only way I was able was to use a #3 phillips socket extension. Like this http://www.ebay.com/itm/snap-on-phillips-socket-drive-3-8-drive-FP42B-/192254029295?hash=item2cc33badef:g:ViYAAOSwblZZIinf
It came right out with the right tool. Casey
Back to top
PostPosted: Mon Aug 07, 2017 5:03 pm    Post subject: Reply with quote
As mentioned a phillips socket drive or vise grip works great.
A good trick to break loose a screw is to first try to turn it in the direction that tightens it.
Back to top
PostPosted: Tue Aug 08, 2017 10:34 am    Post subject: Reply with quote
Thanks for the tips.
I'll be out looking for a impact screwdriver tomorrow. I will equally shop for that snap on Phillips socket.
Cheers.
Back to top
PostPosted: Mon Aug 21, 2017 4:35 pm    Post subject: Reply with quote
As an update, I purchased the impact driver. Fortunately the set had a philips socket (hehe- hadn't earlier known snap on was a brand name...I thought it was the socket itself)...
The job is moving on as desired.
Thanks you.
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
