Old cam with new lifters on rebuild
Author Message
mnkytail
PostPosted: Wed Jun 07, 2017 7:47 pm    Post subject: Old cam with new lifters on rebuild Reply with quote
Any thoughts on using new lifters with old cam? The cam checks out to specs but I thought maybe getting new lifters. Any dangers or things I need to be worried about? Everything is stock.
Back to top
PostPosted: Wed Jun 14, 2017 8:25 am    Post subject: Reply with quote
personally, I prefer working with the original parts that are within specifications as they have proved themselves through the engines life...
My decision, however, is partly dictated a lot by the scarcity of parts in my area.
I believe it should be ok if all items are stock. I'd be all ears as well on the response of others on the same.
Back to top
mnkytail
PostPosted: Wed Jun 14, 2017 8:10 pm    Post subject: Reply with quote
Thanks, everything is stock so I'll give it a shot.
Back to top
PostPosted: Fri Jun 16, 2017 11:29 am    Post subject: Reply with quote
Good luck! Make sure you run a break in for the new lifters.
Back to top
1300
PostPosted: Fri Jun 16, 2017 7:56 pm    Post subject: Reply with quote
I would use a zinc additive for the break in as well.
Back to top
mnkytail
PostPosted: Fri Jun 16, 2017 7:59 pm    Post subject: Reply with quote
Thanks, you guys are great!
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
