Engine Swap
Engine Swap
Hi all, this is my 1st post & its a quick question. My 66 bug is still 6 volt & is just a daily driver. The engine is tired. I have the chance to get a good running dual port 1600. I really don't want to convert to 12 volt (my operating 6 volt radio still has the dealers warranty tag on it!!). Will my generator & stand fit on the dual port manifold & the dog house fan shroud?? I know about the clutch & flywheel, but that should be a straight swap, Right?? Thanks in advance, Roger....
Yes, you can swap the 12 volt generator stand for a 6 volt no problem. You will have to determine if your current flywheel has an o-ring in it or not. Early 66 engines did not have an o-ring. If your current 6 volt flywheel has an o-ring, it will fit the 12 volt crankshaft. You will need a pack of 12 volt flywheel shims to set endplay. The 6 volt crankshaft and 12 volt crankshaft have different diameters. http://www.cbperformance.com/product-p/1362.htm. If current flywheel has no o-ring you will need to find a 6 volt flywheel with o-ring. Hope this helps, Casey
Yes, where the flywheel mates with crank. Until April 66 there was no o-ring on flywheel. There is a step machined on end of crank. It is shallower on a non o ring flywheel, longer on a 12 volt crank, so it will sit deeper in flywheel for o ring to seal. The correct flywheel must mate with correct crankshaft. The flywheel shims are just a bit bigger on inside diameter of shim. I think they are same outer diameter. It will work with newer 1600 engine, you may need a different flywheel. What is your engine number on the 66 engine? Casey
This should answer a few questions better. https://www.thesamba.com/vw/forum/viewt ... t+flywheel
1300 Flywheel
Roger,
My 66 VW has the original transmission and flywheel with a 1500 engine installed as the replacement. When I had it resealed they showed me that the flywheel had been redrilled to accomodate the 1500 to the 1300 transmission. Apparently they are different.
I found my engine # , It's H0366647,, Does that tell you anything as far as the O ring on the 6 volt flywheel goes??? Thanks, Roger1300 wrote:Yes, where the flywheel mates with crank. Until April 66 there was no o-ring on flywheel. There is a step machined on end of crank. It is shallower on a non o ring flywheel, longer on a 12 volt crank, so it will sit deeper in flywheel for o ring to seal. The correct flywheel must mate with correct crankshaft. The flywheel shims are just a bit bigger on inside diameter of shim. I think they are same outer diameter. It will work with newer 1600 engine, you may need a different flywheel. What is your engine number on the 66 engine? Casey
