Hydraulic tapets - adjustment query
Been a while...wow! Hope you're all well. Question! Having run on a pancake (flat 4) engine with the valves adjusted to 1.5 turns, my drive has been a drag (about 1000miles)...worst...terribly loosing momentum on hills. I adjusted the valves to 0-lash today and my-oh-my... 'Haven't I got it all back!!!'
Is there any worry with keeping the adjustments at 0-lash?? Kindly advice.
Re: Hydraulic tapets - adjustment query
KKV270 wrote:Hi.
Just to clarify, you're working on a Type IV (bus) engine?
If you haven't read this, it should clarify any questions.
http://www.itinerant-air-cooled.com/vie ... 46&t=11408
Thanks Hercdrive once again for that resource.
I've gone through it. I probably have a different issue as I adjusted to recommended in the article... It sounds right (very quiet) and drives well now...but will keep testing.
Cheers.
Oh! Yes! It is a type 4
