1966 Frankenstein starter problems
Author Message
66frankenstein
PostPosted: Sun Jun 26, 2016 8:49 am    Post subject: 1966 Frankenstein starter problems Reply with quote
I have a hunting buggy built from a 1966 beetle. I don't know all that has been done, but I know a 12v starter and bushing fit properly. Here's my issue. I had a spark plug wire fail and it ran 3 cylinders for a couple of minutes. I tried starting and ran down the battery. I charged the battery back up and now when I try to start it, the starter rarely engages the fly wheel. When it does, there's a bad grinding noise and it won't start the engine. Please help. I've read through these forums and most of you folks are brilliant.[/img]
Back to top
PostPosted: Tue Jun 28, 2016 9:58 am    Post subject: Reply with quote
seems like you lost teeth somewhere and it just coincided with the wires falling off. Remove the starter and see if teeth are missing. The other issue could be the bronze bushing wore out. I have never seen a flywheel strip out. To prove not the flywheel. Manually turn the engine 1.4 turn by the pulley and try to see if it engages.
Back to top
66frankenstein
PostPosted: Tue Jun 28, 2016 10:11 am    Post subject: Reply with quote
I have removed the starter and no teeth are missing. It was new 2 weeks ago. There are some metal shavings in the bell housing by the starter. I'm beginning to think the bendix isn't fully engaging because sometimes the starter just spins. Sometimes it sounds like it's grinding the flywheel away to nothing
Back to top
WSJ
PostPosted: Mon Jan 23, 2017 9:58 pm    Post subject: Clean up the flywheel teeth Reply with quote
Before you install a rebuilt starter, replace the bushing and clean up the flywheel teeth. Use a Dremel to shape the face of the teeth and a large file to dress the tops. The ring gear is softer than the Bendix gear, therefore, if you hear grinding the ring gear is loosing material.
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
