Kevin's 1966 Beetle - Bay Area
euroimage
Post by euroimage »
in sticking with small steps:
more frames painted up:
and since the car never had one; got the correct flasher bracket
euroimage
Post by euroimage »
finally uploaded older photos
Beware.. lots of pictures
Part 1.. seat stuff, first one is for motivation
euroimage
Post by euroimage »
Part 2 Pedal nonsense.. and the mystery pedal arms
euroimage
Post by euroimage »
Part 3 Misc. Brakes and suspension stuff
euroimage
Post by euroimage »
Part 4 Misc. stuff
ill stop the bombardment for now, just trying to catch up with past work. got a handful of photos left, but ill save that for tomorrow.
mine is a US 1966 and says 1300 on the deck lid as that was the only year the 1300 used on the lid. The 1500 was used from 67 on with Volkswagen on the deck lid. Either way his bug is too cool!
From Resource.com:
1966 (1 Aug 65 to 31 July 66)
Chassis 116,000,001 - 116,1021,300
Engine D 0,000,001 - D 0,095,049 1200 34bhp (DIN)
Engine E 0,000,001 - E 0,006,000 1300 37bhp (DIN)
Engine F 0,000,001 - F 0,940,716 1300 40bhp (DIN)
Note new engine numbering system. The prefix determines the engine type.
1300 engine introduced.
"1300" badge on engine lid.
30PICT/1 carburetor.
Cam bearing added to engine.
Emergency blinker switch.
Ventilated wheel slots and flatter hub caps.
Bigger rear view mirror.
Headlight dimmer moved to turn signal lever.
Centre dashboard defroster outlet.
Horn ring - semi circle.
Ball joint front suspension replaces king pins.
Improved torsion bars and shock absorbers.
Needle wheel bearings replace ball bearings.
Outer door handles changed from square pushbutton to round pushbutton.
Locking front seatbacks were introduced.
1967 (1 Aug 66 to 31 Jul 67)
Chassis 117,000,001 - 117,999,000
Engine D 0,095,050 - D 0,234,014 34bhp(DIN)1200
Engine E 0,006,001 - E 0,014,000 37bhp(DIN)1300(US-M240smog)
Engine F 0,940,717 - F 1,237,506 40bhp(DIN)1300
Engine L 0,000,001 - L 0,019,335 40bhp(DIN)1500(US-M240smog)
Engine H 0,204,001 - H 0,874,199 44bhp(DIN)1500
1500 engine introduced - similar to earlier type 2 (bus, kombi) engine, but without the rear cross member mounting point.
"Volkswagen" badge on engine lid.
12 volt electrics.
Generator increased from 180 to 360 watts.
Voltage regulator moved from generator to under rear seat.
Rear track increased with wider swing axles to 1350mm.
Clutch diameter increased from 180 to 200mm on 1300/1500 models.
130 tooth ring gear (flywheel) replaces 109 tooth.
Dual brake cylinder system (drum brakes).
Front discs (single circuit) on 1500 models to some countries (but not US).
Outside door handle has push button.
Inside door handles recessed.
Two speed wipers.
Back-up lights (on US models).
Vertical headlights replace sloped glass.
US models get sealed beam headlights (other countries retain bulb-and-reflector).
Locking buttons on doors.
Driver's armrest on door.
Slimmer chrome trim on outside.
Driver's outside mirror becomes standard.
Rear anti-sway bar added.
euroimage
Post by euroimage »
darzoom wrote:mine is a US 1966 and says 1300 on the deck lid as that was the only year the 1300 used on the lid. The 1500 was used from 67 on with Volkswagen on the deck lid. Either way his bug is too cool!
Although my engine isnt a 1300 I would rather have the correct badge since it is one of those one year only deals 8)
euroimage
Post by euroimage »
getting down to the last of the old photos; fuel gauge taken apart to get all the overspray off the trim and clean it up
euroimage
Post by euroimage »
Electrical stuff, my favorite crimpers in the world and some home made tools
euroimage
Post by euroimage »
Little bit of cleaning.. still needs a bit more
euroimage
Post by euroimage »
Carpet kit was provided with sale of the car.. but was for the foot rest option. So i ditched it (empi) in favor of a better quality one with pre-cut holes and the headliner..
euroimage
Post by euroimage »
something i didnt want to deal with was the lower defrost hoses, but they were toast. if anyone has hints or tips on replacing the hose without chopping holes in the body or opening up holes inside the car please let me know
kinda cool, but found what seems to be the original key.. too bad i do not have the original ignition cylinder
euroimage
Post by euroimage »
couple of random shots
euroimage
Post by euroimage »
And that gets it pretty well caught up with the older photos. Sorry there is alot of photos and not much description.. that will change with all the new updates, hopefully what was posted is self explanatory.. anyways one of my garage buddies
there is usually a hole in the kick panel that you can use to help get the defrosters on. Another option is to use hard pipe (copper) and insert in the areas between outer and inner quarter to the pipe out of the pan. Then use the silver flex pipe from the end of the pipe. As it is hidden in the between area, it would be hard for the purist to detect.
Also you are probably right that the previous owner put the Volkswagen script on the hood. Sometimes you have to work with what you have.
