Im looking for a engine for my 66. I don't know much about VW engine rebuilding so I need advice if this engine is worth purchasing or not. The seller says its a 1300. He also said it has a seized piston. Do you think its worth the attempt to get it rebuild or not? Like I said I don't know much about these engines so any little input would be appriciated thanks!
Advice needed: to buy this 1300 engine or not.
Much of the decision would depend on how much the seller is asking for the engine. Are you just trying to get an engine to rebuild or are you trying to restore the car to as close to original as possible? If the engine is a 1300, the engine number should begin with the letter F. I don't have much experience rebuilding engines so maybe someone else can give better guidance.
