Tire Pressures
Tire Pressures
I am a bit ashamed to ask this, but what do you recommend for tire pressures on Kumho radial tires? Bentley says something really low and I was wondering if those figures were intended for bias ply tires. I generally put in 24 psi on the rear and 20 on the front, but the tires really look slack. Sidewalls say Max 45 psi, so I was wondering if something like 30 might be better. Thanks!
air pressure in VW tires
I've been told the VW beetle with radial tires should have 17 lbs PSI in the front and 24 PSI in the rear.
Has worked pretty well so far.
Now let's hear from the Experts.
tire pressures
As on the tire topic, I've been meaning to ask, can I compromise for a slightly wider tyre than 155/65/15 and say use 175/65/15 and move on with no worries?
Getting 155/65/15 in my region has been a big nightmare with the clossest I'm getting being 165. No guys stock that size around here.
Kindly advice.
Kindly advice.
Re: air pressure in VW tires
17 front 24 rear is not that far off from 20/24. Like I said, he's in the right range.Roadbug wrote:I've been told the VW beetle with radial tires should have 17 lbs PSI in the front and 24 PSI in the rear.
165-85SR-15 is the universal replacement size.KKV270 wrote:Hi.
Kindly advice.
tire pressures
Hi Blue Baron.
Thanks for the information on the tyre matter. Glad to know I have more options.
Regards.
Regards.
