Full rubber seal re-do
BricksANDaBUG
Post by BricksANDaBUG »
Good Day all!
I am going to tackle a full replacement of the rubber seals for the doors, hood, trunk-lid and crank steel sunroof...
Where is the best place to buy these for my '66?
Are there any "weird" situations I might run into?
Just planning ahead (hopefully)...
Thanks!
Mike P
Wolfsburg West is the best place to buy the rubber and metal trim. You should also pick up a copy of the Bentley VW 1200 workshop manual. While it says it's for the 1200, it covers the '66 model as well.
BricksANDaBUG
Well thank you!
I will do that for sure...
Mike P
oldbugguy
Re: Full rubber seal re-do
Post by oldbugguy »
This post is over 10 years old, but I've got a repainted bug that needs seals. The painter didn't do me any favors by just pulling the old rubber, blasting and painting. I had to beat the trunk channel into shape so that I could re-install rubber. Nerve wracking considering the cost of new paint. I still haven't moved ahead on the engine lid seal and am wondering if you found it possible to glue the seal in place, and if so, what glue you used.
Thanks,
OldBugGuy
