1966 WIPER SWITCH/1967 WIPER MOTOR
need help on wiper set up."how to hook up properly"
1966 switch has the following spades-31b,54,54d
1967 12 volt wiper motor has 31 no spade ,53,53a,53b,31b
does any one know the proper wiring to contacts?
also how does one test this switch with an ohm meter.
Thank You
the solution ended up being very simple.i installed the 66 wiper switch back into the car and then had don from DLWEST convert a 1966 wiper motor to 12 volts...simple ,perfect...DONE
Hi Matt: Glad that worked out - I think this is what most folks do....
http://wolfsburgwest.com/cart/DetailsLi ... 113955811B
John:
you are correct..i was just trying to make use of what was installed in the car.which of course ended up being junk!! NOT ANYMORE :)
I know exactly what you mean - after all the most important thing is that you have working wipers! I remember driving 30 miles in a sleet storm with my first '66 and the wiper motor quit. I ended up driving with my driver window down and my hand out front with a scraper acting like the windshield wiper - it worked but what a pain!
scruffy
Post by scruffy »
Hee Hee! :lol: You can tell a bug owner especially in the winter! we are the ones with chopper mitts on with one arm out the window on the wipers and the other clutching a ice scraper to clear the frost off the inside!!! :lol:
