Steering Column Ground Wire
Has anybody got a picture or two of where the ground wires on the outside of the car go to the steering column? I see a spade at the end of the column and another one on the actual coupler bolt too. I need to see how the wires are hooked up. Thanks. I'm thinking that the spade on the coupler must go to a bolt on the clamp for the shaft, and the one at the end of the column must have a wire that goes to the chassis?
This is a good guide to Horn wiring:
http://www.wolfsburgwest.com/wired/wire ... _12_00.htm
