The 1966 VW Beetle Forum Forum Index The 1966 VW Beetle Forum
This Forum is proudly sponsored by
www.1966vwbeetle.com - "The Site for 1966 Beetle Owners & Fans"
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
empi shifter install
Post new topic   Reply to topic    The 1966 VW Beetle Forum Forum Index -> 1966 Technical or Mechanical Forum
View previous topic :: View next topic
Author Message
VDUB66
PostPosted: Tue Sep 11, 2012 11:46 pm    Post subject: empi shifter install Reply with quote
I bought an empi short shifter, When I installed it, I could not shift into reverse. All the gears work just fine. I used the shift plate that came with the shifter. any help would be helpful. thanks.
Back to top
View user's profile Send private message
PostPosted: Wed Oct 03, 2012 3:01 pm    Post subject: Reply with quote
Stupid question, but you did pull up on the reverse lockout ring before shifting, right"?
If you still can't grab reverse, check the condition of the shift coupler cage under the access plate beneath the back seat. Chances are the rubber cage bushings are shot and are in need of replacement. Urethane bushings are available through the aftermrket. And this advice goes for anyone with air hockey shifting.
Back to top
Display posts from previous:
Post new topic   Reply to topic    The 1966 VW Beetle Forum Forum Index -> 1966 Technical or Mechanical Forum All times are GMT - 6 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You can attach files in this forum
You can download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
