Good evening everybody: The thing is that this afternoon, something happened to my Beetle. I've been driving it for two days, and noted the first gear hard to shift, and the second gear even harder, with a loud metallic scratching noise when shifting. But this afternoon, the cluth pedal suddenly felt "loose", with no pressure, and making impossible to shift any gear, as if a wire were loose or a cluth pump were without any pressure when you push it. I turn off the engine, shift any gear, then turns on the engine and the car runs "jumping", but I can't get anything from the cluth pedal, I can't insert any other gear. My question is: Does the car have a clutch pump? The gears get shifted just with a wire actuator?.
Thank you in advance....!!!!!
