Grinding into 2nd gear
I am having an issue with my bug wanting to grind into 2nd gear. I have replaced the shifter coupling, and shift rod bushing. I tried to install a stock shifter which did not go well at all. I could find 3rd and 4th, but 1st and 2nd were impossible. I put the Scat shifter back in, and it shifts perfectly in 1st, 3rd, 4th and reverse, but I cannot get it to shift into 2nd without grinding. I have spent 2 days trying to adjust the shifter to no avail. I have adjusted the clutch, and changed the gear oil in the trans. I found quite a bit of metal on the drain plug magnet which is making me think that the 2nd gear synchro is gone. Anybody have any experience with this? I think I am looking at having to replace the trans, but I want to eliminate all other possibilities before spending the money on a new trans.
