Ok, we were told this '66 had a gas heater and I couldn't find it, as I thought the heater was located under the front trunk lid.
I have since discovered the heater under the vehicle above the transmission, but have absolutely no idea how to work it.
At this point in time the gas line to the heater is not hooked up, and I don't know why. Maybe it leaks?
Do these heaters have a carb, or how do you control the fuel flow, and what's with the spark plug?
Is the temp adjustable, or is it just full blast, is there a fan with different blower speeds?
Questions questions, hopefully somebody out there can answer them!
Thank you for your time, Volksie's hubby.
How do you work the gas heater??
Thanks for the info guys.
I did some research and I think we have a Webasto??? heater. Unfortunately everything I could find on them indicates they are an extreme fire hazard so I doubt we'll try to use it.
Besides, Volksie says she has no interest in driving the vehicle in the winter anyway. I say good enough, that solves that problem!
I have ordered a Pertronix electronic ignition to eliminate the points. I had a heck of a time finding a set of points for this 1300 motor as they are apparently unique to this particular engine. Probably better to just avoid this issue again and go electronic.
I'll let you know how it works out.
Thanks again...
Thanks again...
Hi Jimbolia, yes, it's made specifically for the 6 volt system. I called Pertronix directly and it turns out my closest dealer is in Calgary AB, Canada.
You can't buy directly from Pertronix, so they kind of give you the run-around finding someplace to order from.
The business I called only places an order to Pertronix once a month, so the order didn't go through until early December. I hope I'll have it early in January.
I'll try it out and post a new thread on how it works and include the part number etc.
Hope that helps, Volksie's hubby.
