Hi,
I recently had to replace my 44 year old pedal assembly, it was still working ... but, the brake pin popped out under heavy braking and lucky for me - the E brake was tight. So, I had to replace it. My search for a 66' assembly was tough - so, I had to replace it with the "standard" replacement assembly. But, what I have found is that the pedals are close, mainly the gas and the brake ... my 66' has a roller gas pedal and I'm wondering if going to a flat pedal will correct this (pulling my foot off the gas, my foot hits the back side of the brake pedal), as a flat gas pedal is ahead of the brake, etc. Or what about a cruiser pedal and using the existing roller pedal together?
Thanks 66'ers !!!
Pedal Assembly Replacement
I had a roller pedal on my baja. Don't remember it being too close to the brake. Maybe that's cuz I spent so much time replacing the throttle cable. I junked the roller pedal and went back to stock, never had that problem again.
Just my opinion, but the roller pedals are junk.
This nation will remain the land of the free only so long as it is the home of the brave. ~Elmer Davis
