exprof
Posts: 85 Joined: Wed Mar 05, 2008 12:45 pm
Post
by exprof » Tue Apr 28, 2009 9:11 pm
My '66 has a 1600 dual port with a Solex 30/31 PICT carb. When it is cold, the engine dies within a couple of seconds of starting. It also sputters and hesitates when I step on the accelerator unless I press it very firmly. If I simply touch the pedal with my foot, the engine quits. I have to rev the engine higher than one normally would in order to start out in first gear. Also, the exhaust smells as if the mixture is overrich.
Thanks in advance for any and all help.
Posts: 1319 Joined: Fri Dec 23, 2005 8:43 pm
Post
by jmartini » Wed Apr 29, 2009 2:40 am
It sounds like it is flooding out when you touch the gas pedal. My guess is that you are correct in thinking the mixture is too rich.
exprof
Post
by exprof » Wed Apr 29, 2009 2:41 pm
I'll adjust the mixture and we'll see if that does the trick.
couion
Posts: 86 Joined: Wed Jul 11, 2007 5:41 am
Post
by couion » Thu Apr 30, 2009 3:24 am
Double check the choke to see if it is adjusted too tight. This would cause it to get too much fuel and not enogh air.
exprof
Post
by exprof » Thu Apr 30, 2009 3:34 pm
I leaned the mixture and it seems to be running o.k.; at least it's not gagging when I step on the accelerator. I'll check the choke also.
Thanks for all your help.
