While admiring all the grease & rust from the worms eye view on my bug, I noticed that my ball joint seals/boots are shot and barely hanging on. There doesn't seem to be any slop there, but without the seals, I am sure that won't remain the case for very long. I have located some replacement seals, but was wondering how much damage I can do to the steering by just taking the nut loose and pulling the joints out. Is this a lot more involved than it looks?
Thanks!
Ball Joint boots
ball joint boots
Better to take off the beam, remove the torsion arms and have a qualifed machinist remove and replace the ball joints. Make sure the camber fittings are on correctly. I almost forgot to put them back on!!!!
whatever you do, do NOT take the torision springs out of the beam!!!!! very difficult, dirty job replacing them.
Might be worth replacing the tie rods if the adjustments are frozen.
