The 1966 VW Beetle Forum Forum Index The 1966 VW Beetle Forum
This Forum is proudly sponsored by
www.1966vwbeetle.com - "The Site for 1966 Beetle Owners & Fans"
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
pop out windows
Post new topic   Reply to topic    The 1966 VW Beetle Forum Forum Index -> 1966 Technical or Mechanical Forum
View previous topic :: View next topic
Author Message
bill hauck
PostPosted: Fri Mar 14, 2008 12:39 pm    Post subject: pop out windows Reply with quote
I am replacing the window to body rubber seals.
They come in one piece. Are they cut to install or are they installed in one piece. The latter appears difficult if not impossible to do.
Back to top
View user's profile Send private message
Moderator
PostPosted: Sat Mar 15, 2008 1:06 pm    Post subject: Reply with quote
Please do not cut
they are installed as one solid seal.The resean for the tight fit is the backward seal motion that is created as the string is worked around the seal lip on the body....if you are also going to install metal strips that must be done while the glass is out,..,.
any other questions just email me we can talk on the phone..
mdazzo@optonline.net
_________________
http://volksbugusa.shutterfly.com/
Back to top
PostPosted: Sun Mar 16, 2008 12:11 am    Post subject: Reply with quote
Ok, hold on, I'm confused. Are we talking standard quarter windows as the posts seem to indicate, or pop outs as the topic suggests? Aren't the prodecures different for pop outs?
Back to top
Moderator
PostPosted: Sun Mar 16, 2008 4:12 am    Post subject: Reply with quote
the question should not have posted under pop outs...anyway I did talk to
Hal and all is well.
Cheers
_________________
Back to top
PostPosted: Sun Mar 16, 2008 6:59 am    Post subject: Reply with quote
Ok, so do I need to change the title to Rear Quarter Windows to avoid confusion...please let me know and I will make the change. Thanks. John
_________________
John
Admin
jmartini@1966vwbeetle.com
Back to top
View user's profile Send private message Send e-mail Visit poster's website
bill hauck
PostPosted: Sun Mar 16, 2008 9:35 am    Post subject: pop out (not conventional rear quarter windows) Reply with quote
Matt, I forget: on the "pop out" windows, do I cut the rubber seal (window to body) seal to install??
Back to top
Moderator
PostPosted: Sun Mar 16, 2008 9:44 am    Post subject: Reply with quote
you might have to cut the pinch ,but i would trial cut so that each side is touching the spring plate...(top of plate,bottom of plate) .when you install the covers the pinch edge should not be seen.
Matt
_________________
Back to top
elkluvadore
PostPosted: Thu Mar 20, 2008 8:58 pm    Post subject: Reply with quote
avoid cutting if possible, itll help keep the water out
_________________
A volksie thanks,
Max
Back to top
Moderator
PostPosted: Fri Mar 21, 2008 3:11 am    Post subject: Reply with quote
the pinch will be longer then needed you will end up cutting or trimming or shaving the pinch to the spring plate.....never cut the outer glass rubber. in fact when replacing the outer seal always make sure the seam in centered on the flat side of the glass
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    The 1966 VW Beetle Forum Forum Index -> 1966 Technical or Mechanical Forum All times are GMT - 6 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You can attach files in this forum
You can download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
